arlee
Feb 10, 2018Follower
AC1200 C6220 Wireless Signal not broadcasting
Hello, My ac1200 cable modem router is not broadcasting any wireless signal. Wired lan connection is still working and I am able to connect to the internet via ethernet. Here are what I have ...
Weatherbrian
May 03, 2018Tutor
I have the same issue. I'm out of ideas.
DarrenM
May 08, 2018Sr. NETGEAR Moderator
Hello Weatherbrian
If the wireless is not broadcasting it could be on your ISP side they may have the wireless disabled and you may need to contact them and make sure everything is coded correctly on your modem.
DarrenM
