MetalGuitarMax
Feb 11, 2017Aspirant
AC1600 - Not Getting Speeds
Today, I finally had time to get a technician out from my ISP. They ran tests, sent signals, replaced my coax cable to bring it to the most modern cable, tested it at the end and said everything was p...
MetalGuitarMax
Feb 13, 2017Aspirant
Hey DarrenM,
How would I go about factory resetting the modem?
Thanks!
Thanks!
- DarrenMFeb 13, 2017Sr. NETGEAR Moderator
You would just need to hold the reset button in for 10 seconds on the back of the unit after that you will have to set it up agian.
DarrenM
