Jechance72's avatar
Jechance72
AC1600 C6250 Internet connection drops intermittently
I purchased this cable modem back in early July and within the last few weeks it seems to be dropping the Internet Connection often (3-4 times a day). I took a snapshot of the Event Log and Cable Connection power info to see if that could shed any light on an issue.  If I reboot the router the connection comes back, but it's annoying when I'm in the middle of doing something online and I have to do this. Is there any solution or do I need to try and return the unit?
  • Any suggestions? I've lost connection so far twice in the last 6 hours.
    • vkdelta's avatar
      vkdelta
      NETGEAR Employee Retired
      who is your ISP? ( I am guessing it is not Comcast).
      you Upstream (US) power is reaching its limit (51 dBmV) and your ISP does not want to enable extended US power for your device. Most likely the issue is on your line by the ISP and they need to tune your cable to reduce the US power from the Modem.
      • vkdelta's avatar
        vkdelta
        also, please post full screenshot of the event logs.
