SulleyBoo7271
Apr 09, 2018Aspirant
AC1750 Channel Selection and Signal Quality
I have a C6300 Wifi cable modem router that I cannot seem to obtain a quality signal with and need assistance. The singal strength seems to be good with MOST of my devices and the connection speed wi...
DarrenM
Apr 12, 2018Sr. NETGEAR Moderator
Do you get the same result in skype on multiple devices or is it just one having the issue?
DarrenM
SulleyBoo7271
Apr 12, 2018Aspirant
Yes, seems like it is simply poor speeds or quality on the wireless devices.
The singal strength is good on my laptop, but when Skype is being used, the Skype connection indicator shows poor connection.
My speeds are horribly slow, about 50Mbps on wireless and 100+Mbps when using a wired connection.
