idiotbox37
Jul 07, 2016Aspirant
AC1750 (r6400) No internet connection through CM500 (xfinity)
I had a comcast tech unsuccessfully install my hardware. After an hour on the phone w/ tech support I have internet access(with annoying connectivity issues) when my laptop is directly wired to the m...
DarrenM
Jul 12, 2016Sr. NETGEAR Moderator
Hello idiotbox37
The DNS is pushed out through comcast servers have you tried to change the DNS on the router and your devices to googles dns?
DarrenM
idiotbox37
Jul 15, 2016Aspirant
i did try manually setting the DNS to comcast servers and then google dns but that didn't work. I found another forum thread that suggested having the router clone the PC's MAC but that didn't work. I decided to try "turning it off and on again" and i found netgear's suggested power cycle instructions. I tried it a few times and it didn't work. AND THEN, i tried it again, and all lights lit. I have no idea what happened. i don't know if comcast pushes dns settings periodically and the last time just happened to sync w/ their push? The dns issue did seem to be between the router and modem but i was having serious latency issues when wired directly to the modem so the connection through comcast wasn't healthy either. I've been stable since. good bandwidth and low latency. I don't know what will happen if i ever have a power outage haha. Thanks for the suggestion, DarrenM.
