idiotbox37
Jul 07, 2016Aspirant
AC1750 (r6400) No internet connection through CM500 (xfinity)
I had a comcast tech unsuccessfully install my hardware. After an hour on the phone w/ tech support I have internet access(with annoying connectivity issues) when my laptop is directly wired to the m...
idiotbox37
Jul 15, 2016Aspirant
i did manually set the DNS to the Comcast addresses (75.75.75.75 and 75.75.76.76) as well as the google dns address you listed. ping would time out if i tried something outside my network. No difference in MS Edge or Chrome browsers. DNS lookups w/ nslookup failed as well.
My access is working after i power cycled the hardware multple times.
VE6CGX
Jul 15, 2016Master
If you can connect PC directly to the modem and try if samething happens. If it does it must be modem problem.
