andy792's avatar
andy792
Tutor
Jul 28, 2017
AC1750 router/modem won't show up on network list
I don't know if anyone else has had this issue. My wifi has been working correctly and last night, my router just disappeared from the network list. I thought my ISP was having problems so I didn't think too much about it. But even if my internet signal was out, wouldn't I still see the network on the list? I can't see it on any of my devices. My laptop which runs Windows 10, my iPhone, or my PS4. Firmware version is V2.01.18. I've called support twice and they told me to reset it and it seems to work, but I don't want to have to keep resetting it if it goes out. I would like a permanent solution. The model of my router is an AC1750 dual band router/modem.
  • michaelkenward's avatar
    michaelkenward
    Which hardware are we talking about? AC1750 isn't a Netgear model number. It could be a router, modem or cable modem.
    Where is this list? Wifi sources?
    If the Internet goes off, it will show in the lights on whatever device we are talking about here.
    • andy792's avatar
      andy792
      Tutor
      Sorry about that. It's a c6300, so it's a modem/router. Well the list is what shows up on your computer when you try to connect to the wifi. Like when you click on the wifi signal on the bottom right.
        michaelkenward
        OK. It can't see the wifi.
        I asked because there are various places where things appear on the network, as wired or wireless devices.
        I assume that this bit refers to Windows.
        If so, the problem could be with Windows rather than the wifi from the modem router.
        When the network disappears, do you still see the wifi LEDs on the c6300?
        If you haven't found it already, the manual is here:
        >>>> C6300 | Product | Support | NETGEAR <<<<
        It looks like yoiu have the latest firmware:
        What’s the latest firmware version of my NETGEAR cable modem or modem router?
        As you say, even if the Internet died, you should still see the wifi.
        When you say support told you to reset the thing, is that ISP support or Netgear? Did that reset include factory reset?
