bpri
Oct 17, 2015Aspirant
AC1750 Smart WiFi Router
Does this boost WiFi speed or just extend the coverage? I don't see a difference between my old router and this one. Also does the gigabyte work only when connected via cable I don't really know much ...
DarrenM
Oct 19, 2015Sr. NETGEAR Moderator
Hello bpri
The AC1750 refers to the wireless speed of the 2.4 and 5ghz bands. And it might not be better coverage than your old router just depends on the space it needs to cover. And yes the gigabyte is referring to the the ethernet connection.
DarrenM
