lildestiny's avatar
lildestiny
AC1750 WIFI CABLE MODEM ROUTER DROPPING WIFI CONNECTION CONSTANTLY
Hello,
For the past several weeks my modem router AC1750 has been dropping wifi connection. It happens several times a day, the connection blinks out and comes back or drops for several minutes. I have unplugged 60 seconds and replugged it (I do this every day for work) and that doesnt seem to fix it. Im not a techical person so im not sure what more to do. My ISP is spectrum and they say everything is fine on their end. I pay for 400 download and 20 upload. Wired I getting 240 download and 20 download, wifi im getting 28 download and 25 upload (thats with my laptop sitting right next to the modem). I was going to try https://kb.netgear.com/23783/Improving-2-4Ghz-Wireless-Performance-by-Changing-Channel but the link  http://www.routerlogin.net doesnt open for me. Please help me!
Thank you!
  • plemans's avatar
    Try access the router at 192.168.1.1 or 192.168.100.1
    • lildestiny's avatar
      lildestiny
      192.168.1.1 This site can’t be reached, it took too long to respond. 192.168.100.1 This page isn’t working, invalid response.
  • FURRYe38's avatar
    Has a power OFF of the RBR and RBS for 30 seconds since last FW update been performed?
    lildestiny wrote:
    Hello,
    Thank you!
      lildestiny
      I have no idea what channels Im using. Where would I see this and make these changes? Im not sure where to login to gain access to the modem. Yes my computer can see 3 wifi networks from my neighbors, all very weak signals.
      • plemans's avatar
        If you have the C6300, try factory resetting it. push and hold reset for 7-15 seconds while its powered on.
