camera1_
Apr 30, 2023Follower
ac1900 / c7000
Router not blocking blocklist:
ticktok
ticktok.com
https:/tiktok.com
- plemansGuru - Experienced UserThe problem is more than likely related to the httpS The secure site's address is encrypted and won't block. it makes the site blocking feature a bit pointless and you'll see a ton of posts on the forums about it.
 camera1_ wrote:
 Router not blocking blocklist: ticktok ticktok.com https:/tiktok.com Not much to go on there. It is anybody's guess as to what you did on your modem/router. While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
 You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
 Cable Modems & Routers
 You might like to search there for messages related to your problem.
 I will ask the Netgear moderator to move your message.
 In the meantime you could visit the support pages:
 Support | NETGEAR
 Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
 Check for various troubleshooting tips.
 You may have done this already. I can't tell from your message.
 I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
