beh
May 08, 2017Aspirant
AC1900 Cannot reset password
I have read the information on how to find the "reset password" function but when I try to change my password from the factory default password I always get a "failed" response. Are there criteria fo...
beh
May 09, 2017Aspirant
My modem/router is the AC1900 C700 100NAS.
I have tried using both Chrome and Explorer browsers. In the Chrome browser I get a "failed" notice. In the Explorer browser I get a "certificate expired and failed" notice. There is an instruction to go to the "menu" to correct but no indication as to exactly "what" menu.
Very frustrating as I simply have never been able to figure out where I am screwing up.
thanks
michaelkenward
May 09, 2017Guru - Experienced User
Is this the C7000? (Note the extra 0.)
If so, did it come from your ISP? If so, these things can end up tweaked in ways that only they can understand.
I'm a bit confused by your latest message. Are you saying that you cannot access the modem's control interface? Your first message led me to believe that you had got that far.
Page 76 of the manual shows how to get there:
- behMay 09, 2017Aspirant
It is the C7000.
The error messages happen in trying to change the password using the Advanced > Administration > Change Password page.
I have finally sorted it out and thank you for your assistance.
- michaelkenwardMay 09, 2017Guru - Experienced User
