cyd777
Nov 23, 2016Aspirant
AC1900-Nighthawk DOCSIS 3.0 Cable Modem Router Model: C7000 dual stack lite (ds-lite) compatibility
Dear All, I would like to ask before I buy this device if this one has dual stack lite (ds-lite) compatiblity or not? This is a requierment from my provider. Thanks, Janos
cyd777
Yes I talked with the presales support on chat. It is not supported on this device, but the problem that is requirement by provider (German Unitymedia).
I don't want this but my provider do, So what can I do?
Anyway thanks.
TheEther
Nov 23, 2016Guru
Well, try asking over on unitymediaforum.de for help. There is much dislike for DS-LITE, there. I saw two possible solutions:
- Get a Fritzbox
- Upgrade to a business account. Then you can get a public IPv4 address. It will almost certainly cost you more money.
Good luck!
