mtlwrx's avatar
mtlwrx
AC1900Modem/Router- I cannot finish network setup-
I left the network set up page before I finished it. I cannot find that page again to finish the network set up. Now, I have no network
#networksetup
  • FURRYe38's avatar
    Factory reset the modem and setup from scratch. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
    Besure to clear out all browser caches.
    Try using a different browser. MS Edge, Firefox or Opera is recommended.
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    • mtlwrx's avatar
      mtlwrx
      Furry
      Thanks for your reply
      But,....
      I did the reset, &  unplugged (from power)
      and nothing changed
      I still can't pull up the "Set up new network" page
      I tried the reset password instructions, but I can't pull up any page with that active prompt
      I go to settings, click "available networks", "netgear 38" comes up, asks for network key, I did not create one, so, nothing happens
      Thanks again
      • Kitsap's avatar
        Kitsap
        Master
        mtlwrx wrote:
        Furry
        But,....
        and nothing changed
        Thanks again
        Look at the nameplate on the back of your unit.  The nameplate lists the default SSID and the Wi-Fi password for the default SSID.  Use these to log in to the Wi-Fi.
    • mtlwrx's avatar
      mtlwrx
      ADDITION TO MY REPLY
      I cannot get "The Set Up Wizard" to appear
      Is there any downloadable software available for this piece?
      Thanks
      • FURRYe38's avatar
        Nothing seen at 192.168.1.1 in a web browser on a wire connected PC?
        Last resort, you might try a 30-30-30 reset,
        Thanks
