bestaudioguy's avatar
bestaudioguy
AC199 EX700 will not work with CM1000 modem
We just switched from DSL to cable using a new Netgear CM1000 modem on Comcast.   The tech came out to connect it and it works fine.  Tried to connect the Netgear AC1900 EX7000 wifi access point and ...
  • vkdelta's avatar
    Jul 25, 2017
    EX7000 is an "EXTENDER" and not a "ROUTER".
    you need a router such as R7000, R8000, etc
