holdem
Aug 26, 2025Follower
Access denied errors attempting to login to management interface
I have C3700v2 also, I have reset the unit twice to factory default settings due to access denied errors attempting to login to management interface.
Since the unit is no longer under warranty, I have no other option other than to open a ticket and allow tech support to attempt a maintenance check.
I'll update with the results.
1 Reply
Disconnect the ISP Coax cable from the modem. Reset the modem by pressing the reset button for 15 seconds then try to access the modems setup wizard using a ethernet connected PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
