whynotme's avatar
whynotme
Access Points not being assigned IP address
Tried to replace my Xfinity 1Gb gateway with this new CM1150V but none of my 3 access points are getting an ip address.  I've tried it with a Netgear router AC1700 and 2 different Ruckus Wireless ap's, an R710 and R730.  My laptop is hardwired to the new modem and that works fine.  Something about this modem won't assign ip addresses to routers/access points.  Anyone have any thoughts before I return this?  Having put the Xfinity gateway back in the network, the ap's and Netgear router all pull ip addresses just fine.
Thank you
  • > Tried to replace my Xfinity 1Gb gateway with this new CM1150V [...]
       Why?  Was there some actual problem which you were trying to solve?
       What, exactly, is your "my Xfinity 1Gb gateway"?  If it's some kind
    of (cable-TV-type) modem+router, and you replaced it with a simple
    modem, then I'd expect many things not to work as before (if at all).
    > [...] Something about this modem won't assign ip addresses to
    > routers/access points. [...]
       Yes. The fact that it's a modem, not a router with a DHCP server.
    > [...] the ap's and Netgear router [...]
       What, exactly, is your "Netgear router"?  Is it configured as a
    router, or as a wireless access point?
    • whynotme's avatar
      whynotme
      I was trying to replace my rented Xfinity modem with an owned device to remove the $13 modem rental fee.  The Xfinity is model TG3482G.  I was running in bridge mode, so the router function was turned off.
      Can this modem not act as DHCP server?
      • antinode's avatar
        antinode
        Guru
        > I was trying to replace my rented Xfinity modem [...]
        > [...] TG3482G [...]
           An ARRIS TG3482G is a "gateway" (modem+router), not a simple modem.
        > [...] I was running in bridge mode, so the router function was turned
        > off. [...]
           If the router functions of the TG3482G were disabled, then I'd expect
        its DHCP server to be disabled.  If all you did was disable its
        wireless-network radios, then its "router function" was not "turned
        off".
           Generally, a _modem_ does not include a DHCP server.  A _gateway_
        (modem+router) or a _router_ will include a DHCP server.  A Netgear
        model "CMxxxx" is a modem, not a gateway, so no DHCP server.  (Also, no
        other router functions.)
