clinew0791
Mar 29, 2022Follower
adding a secondary modem router as a hotspot wirelessly connected to a primary modem router
I would like to know if it is possible to configure the following.
I have researched this and tried it several times but keep hitting a brick wall so I am not sure if its that I am missing a setting/configuration or what.
Primary cable modem router connected to Xfinity via coax = C6300v2
Secondary cable modem router = C6230
I would like to use the secondary router (C6230) as a hot spot on the opposite end of the house and connect it wirelessly to the main router (C6300v2)
Is this possible? If so, how?
