louisam
Oct 23, 2022Follower
affordable connectivity program
Is any of the all in one bundle cable modem router compatale with affordable connectivity program.
Please contact any and all ISP service companies to see what they support on there networks. They will have this information.
Thank you.
The affordable connectivity program is a federal program that allows you to get a cheaper rate from your ISP and the govt pays part of it for you. It has nothing to do with what modem/router you have. Its more about whether the ISP supports the program or not. So like FURRYe38 says, contact your ISP to see if they support the program and if you qualify. If you do, then ask them what equipment you need for their service
