JMcLeod
Jul 18, 2021Follower
after installing the new modem with my ISP some apps won't work on WiFi
Any help on something we may be missing to get this to work through a Bravia smart tv through WIFi. Everything else works fine
schumaku
Jul 18, 2021Guru - Experienced User
Unclear what "everything else works fine" means here. The CM1100 is a pure cable modem, no NAT router, no WiFi - as such you can connect only one device direct to it, typically a computer as required for the initial config to your cable TV provider. For anything more, you need a WiFi router.
Most cable ISP assign only one public IP to such a device. Even if there are multiple LAN port, only one device can be connected direct. The reason for two LAN ports is the ability to run port aggregation to a capable NAT router allowing to reach total bandwidth beyond of what a single Gigabit Ethernet link allows.
