LML
Nov 18, 2016Aspirant
After update can't configure access control (MAC filter)
My netgear modem/router was updated at some point without my knowledge, and now has a new "genie" interface when logging in through a browser. In the old interface I was able to set up a MAC add...
michaelkenward
Nov 19, 2016Guru - Experienced User
I have heard of ISPs forcing updates on people, but not Netgear. How do you know that the firmware was updated if you can't get into the router?
When you do an update yourself, either downloading the file or letting the Netgear genie do it, it may help to reset the thing back to the factory settings. (The manual will tell you how to do this.)
Ryanselfaz wrote:
What do I do? I don't monitor this board so please email me directly thanks.
That's not how this place works. It is a user-to-user self support forum. If you want answers, stick around. Then people who think that I am writing nonsense, which is quite likely, can step in an correct me.
If you want direct support, then you need to go through the official support channels. But that may cost you.
