LML
Nov 18, 2016Aspirant
After update can't configure access control (MAC filter)
My netgear modem/router was updated at some point without my knowledge, and now has a new "genie" interface when logging in through a browser. In the old interface I was able to set up a MAC add...
michaelkenward
Nov 19, 2016Guru - Experienced User
LML
Nov 19, 2016Aspirant
thanks Michael (unfortunately ryan has hijacked this post with a different problem). I'm restating the issue, with the correct model number this time:
My netgear modem/router CG3000DV2 was updated at some point without my knowledge, and now has a new "genie" interface when logging in through a browser. It previously had the dark blue UI with buttons on the left side--now it has "genie" interface with more colorful UI. I did not initiate this update--it did it automatically somehow (or I was hacked?)
In the old interface I was able to set up a MAC address list to ONLY ALLOW devices that I selected (i.e. my own devices). Now it seems all I am able to do is BLOCK a specific device.
What happened? Is this feature no longer available?
LML
Netgear CG3000DV2 N450 genie Firmware Version V3.01.06
- michaelkenwardNov 19, 2016Guru - Experienced User
LML wrote:thanks Michael (unfortunately ryan has hijacked this post with a different problem).
And how. Different hardware, different problem, wonky approach.
But my suggestion to him still stands. Did you "factory reset" the device?
Maybe your ISP forced the update on you. DOCSIS is alien territory to me.
The manual for your kit is here:
N450 | Product | Support | NETGEAR
There is other support stuff there too.
Such as:
How do I perform a factory reset on my NETGEAR router?
Do that and you may recover control of your network.
If not, how are you connecting to the CG3000DV2?
Try: http://192.168.0.1
- LMLNov 19, 2016Aspirant
thanks Michael, unfortunately you're confusing my issue with Ryan's :(
I have access to my router. I am starting a new thread in hopes of getting clearer advice
LML
- michaelkenwardNov 20, 2016Guru - Experienced User
LML wrote:thanks Michael, unfortunately you're confusing my issue with Ryan's :(
LML
I am not confusing the issue.
My advice is the same.
RESET THE ROUTER TO FACTORY SETTINGS.
This is standard troubleshooting procedure, especially if you have somehow got new firmware.
