mholmes205
Sep 11, 2018Follower
Apple Airport Time Capsule & C7100V Nighthawk
I just installed a new C7100V to replace the rented Xfinity gateway.
With the Comcast set up, I had their router in bridge mode, and used my Apple Airport Time Capsule for my Wifi needs.
vkdelta
Sep 11, 2018NETGEAR Employee Retired
Step-1, turn off WIFI
Step -2 Configure Nat mode = NO (this is same as Bridge mode = YES)
Step 3 Connect ONE and ONLY ONE device on the ethernet LAN port after C7100V is powered ON. Most people make mistake of connecting multiple devices. If you change the devices on LAN port of C7100V, please REBOOT the devices to learn new MAC ADDRESS from the LAN device.
step 4. Connect your laptop behind apple router and check for internet. If it does not work, try FACTORY RESET on APPLE Airport express.
