thepadlos
Oct 22, 2025Aspirant
AX4200 Limits
I have an AX4200 with one satellite. Only my download light is on. I am no longer able to consistently stream Amazon Music on multiple speakers. I have a 1 GIG download, but 50 WIFI devices connected...
- Oct 30, 2025
You'll need to get with the ISP and have them help you with the modem signal side of things. Ask for a tech on site visit.
Might try a power off of the CBR for 1 minute then back ON or try a full on factory reset and setup from scratch:
Should be good with those devices as along as you have a satellite to connect and have devices connect to the RBS.
thepadlos
Oct 23, 2025Aspirant
Thank you. I have cycled the router/modem as indicated. WIFI speed consistently drops from 650 to 200 which correlates to drop of streaming music. Please see below.
- FURRYe38Oct 23, 2025Guru - Experienced User
Please include the data on the page farther down the Cable Connections page.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
FW level is good and current for both CBR and RBS. Do not let the RBS be updated beyond v4.
