thepadlos
Oct 22, 2025Aspirant
AX4200 Limits
I have an AX4200 with one satellite. Only my download light is on. I am no longer able to consistently stream Amazon Music on multiple speakers. I have a 1 GIG download, but 50 WIFI devices connected...
- Oct 30, 2025
You'll need to get with the ISP and have them help you with the modem signal side of things. Ask for a tech on site visit.
Might try a power off of the CBR for 1 minute then back ON or try a full on factory reset and setup from scratch:
Should be good with those devices as along as you have a satellite to connect and have devices connect to the RBS.
thepadlos
Oct 26, 2025Aspirant
Although not cleared by me, my Events Log is suddenly empty?
- FURRYe38Oct 26, 2025Guru - Experienced User
Thought power levels are mostly in spec, kinda all over the place from low channels to higher channels. Should be mostly in same range of power across all channels.
Correctables and un-correctables that should be mostly zeros.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
