thepadlos
Oct 22, 2025Aspirant
AX4200 Limits
I have an AX4200 with one satellite. Only my download light is on. I am no longer able to consistently stream Amazon Music on multiple speakers. I have a 1 GIG download, but 50 WIFI devices connected...
- Oct 30, 2025
You'll need to get with the ISP and have them help you with the modem signal side of things. Ask for a tech on site visit.
Might try a power off of the CBR for 1 minute then back ON or try a full on factory reset and setup from scratch:
Should be good with those devices as along as you have a satellite to connect and have devices connect to the RBS.
thepadlos
Oct 26, 2025Aspirant
Thank you for your suggestions. Helpful, but beyond my skill set.
Anything beyond the following that would prompt my ISP to reassessment of my connection?
- Power levels imbalance 6.4 (1.4 to 7.8) exceeds normal range (3.0)
- Correctables should be zero
- Frequent Critical/Warning entries in the event log (However, my Event Log has gone blank?)
In you opinion, is the AX4200 capable of handling 50-60 WIFI devices?
- FURRYe38Oct 30, 2025Guru - Experienced User
