dubbob's avatar
dubbob
Follower
Dec 30, 2022
AX6000 Cable Modem Router Partial Service Mode
Hi all, been dealing with this issue for quite sometime.  No splitters to remove, new ones were installed a couple months ago when ISP visited and said they could find nothing wrong with the line.  They suggested modem was the issue, new modem.  New coax from modem to wall.
I get dropped internet that only comes back when I reset the modem/router.  I unplug and plug back in and it starts up again fine.  Somedays it drops out several times.  Somedays it doesn't drop out at all.  Average at least a dozen times a week.
Looking at the admin portal - it says my cable connection status is Poor.
There are a number of critical notices as well. I'm fairly certain I have a bad line outside.  But I don't know how to convince Xfinity of that.
Help?
Cable Diagnostic
Status:   Poor
Action:
[Partial Service]
Cable Connection
Cancel Apply
Cable Diagnostic
Status:   Poor
Action:
[Partial Service]
If the Partial Service mode does not go away within a few hours (Click the Refresh button after each step):
1) Make sure the coaxial cable is tightly connected.
2) Remove any unnecessary splitters.
3) Replace any required ones.
4) Contact your service provider for troubleshooting help.
[Downstream SNR]
Try these actions (Click the Refresh button after each step):
3) Replace any required splitters.
Internet Access:
Downstream Status:
Upstream Status:
 Refresh Save Cable Diagnostic Info
Advanced Information
Frequency Start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel771 MHzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabled
Downstream Bonded Channels (Partial Service)
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1Locked256 QAM37771000000 Hz7.3 dBmV41.6 dB00
2LockedUnknown9603000000 Hz5.8 dBmV41.6 dB328817095
3Locked256 QAM10609000000 Hz5.8 dBmV41.7 dB00
4Locked256 QAM11615000000 Hz5.7 dBmV41.8 dB00
5Locked256 QAM12621000000 Hz6.1 dBmV34.4 dB400666211259245
6Locked256 QAM13627000000 Hz6.0 dBmV31.3 dB463783912320558
7Locked256 QAM14633000000 Hz6.1 dBmV33.1 dB25644918005127
8LockedUnknown15639000000 Hz6.0 dBmV33.1 dB1015553581
9Locked256 QAM16645000000 Hz6.1 dBmV41.6 dB00
10Locked256 QAM17651000000 Hz6.4 dBmV41.6 dB00
11Locked256 QAM18657000000 Hz6.3 dBmV41.7 dB00
12Locked256 QAM19663000000 Hz6.5 dBmV41.8 dB00
13Locked256 QAM20669000000 Hz6.6 dBmV41.8 dB323367
14Locked256 QAM21675000000 Hz6.7 dBmV41.2 dB130245
15Locked256 QAM22681000000 Hz6.7 dBmV41.7 dB5293
16Locked256 QAM23687000000 Hz6.9 dBmV41.7 dB810
17Locked256 QAM24693000000 Hz7.0 dBmV41.8 dB00
18Locked256 QAM25699000000 Hz6.8 dBmV41.7 dB00
19Locked256 QAM26705000000 Hz6.9 dBmV41.7 dB00
20Locked256 QAM27711000000 Hz7.0 dBmV41.7 dB70
21Locked256 QAM28717000000 Hz7.0 dBmV30.5 dB4060236816166450
22Locked256 QAM29723000000 Hz7.1 dBmV32.5 dB149653082831915
23Locked256 QAM30729000000 Hz7.4 dBmV32.5 dB44051233768
24Locked256 QAM31735000000 Hz7.3 dBmV32.5 dB34491182831
25Locked256 QAM32741000000 Hz7.3 dBmV32.5 dB21637114604
26Locked256 QAM33747000000 Hz7.2 dBmV31.1 dB1221856119475
27Locked256 QAM34753000000 Hz7.4 dBmV29.4 dB717677711449
28Locked256 QAM35759000000 Hz7.1 dBmV32.5 dB3227660476295
29Locked256 QAM36765000000 Hz7.3 dBmV30.6 dB67169689105276
30Locked256 QAM38777000000 Hz7.3 dBmV41.7 dB00
31Locked256 QAM39783000000 Hz7.6 dBmV41.8 dB00
32Locked256 QAM40789000000 Hz7.6 dBmV41.8 dB00
Upstream Bonded Channels (Partial Service)
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA135120 Ksym/sec35600000 Hz41.0 dBmV
2LockedATDMA92560 Ksym/sec10400000 Hz30.8 dBmV
3LockedATDMA105120 Ksym/sec16400000 Hz35.3 dBmV
4LockedATDMA115120 Ksym/sec22800000 Hz41.3 dBmV
5LockedATDMA125120 Ksym/sec29200000 Hz39.8 dBmV
6LockedATDMA142560 Ksym/sec40400000 Hz42.0 dBmV
7Not LockedUnknown0000.0 dBmV
8Not LockedUnknown0000.0 dBmV
Downstream OFDM Channels
ChannelLock
Status
Modulation /
Profile ID
Channel
ID
FrequencyPowerSNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,3159957000000 Hz7.98 dBmV40.8 dB1126 ~ 296953795785436564240
2Not Locked000 Hz0 dBmV0 dB0 ~ 4095000
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Not Locked000 Hz0 dBmV
1 Reply
