KWo
Oct 09, 2015Follower
BBC Article: Netgear router exploit detected
Hi - just read this article. (See below.) It sounds like Netgear has known about this problem for a few months, but this is the first that I've heard about it. We purchased a Negear Wifi Cable Mode...
JackInWa
Oct 11, 2015Aspirant
Hi Kwo, I think your router model would be the C3000. If that is correct you can get the user manual here: http://www.downloads.netgear.com/files/GDC/C3000/C3000_UM_21Aug2014.pdf Or you can find the link on this page: http://www.netgear.com/home/products/networking/cable-modems-routers/C3000.aspx See page 15 "Log In to the Modem Router". And page 83 "Remote Management".
