Dboy501
Apr 29, 2020Guide
Blinking upstream light
It's actually a c7000v2. But the upstream light won't stop blinking no matter what I do, and it's been like this for 4 days. I e tried resetting it in every way possible, even a factory reset. I've already talked to Xfinity and they say the signal os good, and the problem is with the hardware. It's less than 6 months old. The 1st screenshot is with it solid, and the second is flashing
- Dboy501Guide
- Yhayden1InitiateI’m curious if you ever got this resolved. I’m running into the same issue where I’ve had xfinity out and the signal is good. My Netgear C7000.v2 will work for 30 minutes then lose the signal for 10-15 minutes having the upstream blink or internet light blink. I contacted NG multiple times this week confirming that my isp is set appropriately and that my hardware is the Most up to date. I have been on the phone with both Netgear and xfinity all week and just want this issue resolved. It seems to be a consistent issue with the modem. Any suggestions or advice on how you had this resolved would be appreciated/ were you able to get a refund ?
- JimmyVinoInitiate
This problem was driving me crazy and I finally found that the isp cable going to my modem wasn't fully secure. I had to really press it into the the metal sheath and clamp it down so it would stay in place.
