CraftedSuds
Apr 27, 2020Follower
Blinking upstream
Blinking upstream. ISP says their end is fine. Uploaded log. Thank you for your help
Apr 28, 2020Guru - Experienced User
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Check the user manual for LED behaviors.
