FedoraMane
Dec 10, 2016Aspirant
Block a DoS attack in a C3000 100-NAS?
I'm receiving multiple different DoS attacks. It's not too bad, since it's not knocking my internet out for hours on end. But it is disrupting traffic to my servers, and causing my family to disconne...
TheEther
Dec 10, 2016Guru
Your router is blocking the attacks. The problem is that the attacks need to be prevented from reaching your Internet link in the first place. Otherwise, your link will still be congested. Unfortunately, there's nothing you can do directly on your end. With a C3000, you can't even change your IP address. You could try asking your ISP for help.
