Marco-MONACO
May 12, 2016Aspirant
Bridging vs. access point
Dear All, I have the possibility to change the old ADSL contract (around 15mb) where I presently use my netgear DG834g V3. I have a FIX IP contract and a VPN settled and working fine. I have to...
TheEther
May 12, 2016Guru
The DG834g V3 has 100 Mbps Ethernet ports, so wired connections should be able to reach the higher speeds. OTOH, it only supports 802.11g Wi-Fi. The best you can hope to achieve with it is around 22 Mbps to 24 Mbps.
Marco-MONACO
Thanks for the info
