JohnSullivan
Mar 04, 2018Aspirant
Buying a cable modem with voice for Comcast
I am currently using an ARRIS SB6121 Cable Modem with a Netgear R6200 Smart WiFi Router. Comcast shows that my cable modem is not supported so I'm looking for one that is. I recently upgraded my com...
- Mar 04, 2018
wait for CM500V to be in stock and use that with R6200 router you have.
CM500V is modem-only + Voice device (no Router + WIFI).
antinode
Mar 04, 2018Guru
> [...] Netgear Nighthawk AC1900 (24x8) DOCSIS 3.0 WiFi Cable Modem
> Router Combo [...]
Not a model number, is it?
> [...] I already have a very decent Netgear Router [...]
Also not a model number.
> Model: R6200v2|AC1200 Dual Band Gigabit Smart WiFi Router
Is it that?
> [...] I can't seem to find just the Netgear C7100V
Visit http://netgear.com/support , put in your prospective model
number ("C7100V"), and look for Documentation. Get the User Manual.
Read, to learn what you think that you want really is.
On the bright side, you could probably configure your existing "a
very decent Netgear Router" as a wireless access point, and use it to
improve your wireless coverage. (Look for "Wireless Access Point" in
the R6200v2 User Manual, for example.)
- JohnSullivanMar 05, 2018Aspirant
Your answer was not useful, however vkdelta (Netgear employee) did provide the answer I needed.
