JohnSullivan's avatar
JohnSullivan
Buying a cable modem with voice for Comcast
I am currently using an ARRIS SB6121 Cable Modem with a Netgear R6200 Smart WiFi Router.  Comcast shows that my cable modem is not supported so I'm looking for one that is. I recently upgraded my com...
  • vkdelta's avatar
    Mar 04, 2018
    wait for CM500V to be in stock and use that with R6200 router you have.
    CM500V is modem-only + Voice device (no Router + WIFI).
