GeoK2033's avatar
GeoK2033
Follower
Jun 18, 2018
Buying a cable modem with voice for Comcast
I'm trying to buy a combo cable modem/ router with voice. Does the AC 1900 have the Puma 6 chip set?
    First, which cable modem/router are you looking at? See https://www.approvedmodems.com/do-not-buy-list.html, the Netgear  C6300 and Netgear CM700 both are, unless they've been updated.
    Secondly, Comcast probably doesn't allow customer owned eMTA modems (at least I know Spectrum does not) and I don't think Netgear makes any, much less in a modem combo.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    two devices that compatible with XFINITY VOICE are
    CM500V (Modem + Voice only)
    C7100V (Modem Router + WIFI + VOICE)
    If you already have a router, you can just get the CM500V.
