californiawave's avatar
Aug 31, 2017
Buying a modem for Comcast
Hi! I just signed up for Comcast internet, switching from ATT DSL, and need to buy a modem. Here is what I got- Performance Plus (55 mbps/50GB); may possibly switch to Performance Pro (200 mbps/100GB plan).
I'm thinking about getting Netgear CM400. Is it sufficient? Or is CM600/CM700 better?
More importantly, is CM400 compatible with N900 rounter that I currently own?
Thank you for your help.
  • go with CM600. It is 24x8.
    all the modems will work with N900 router.
