anth1225's avatar
anth1225
Buying Nighthawk AC1900
Hello, I have Comcast service with voice, TV and Internet and I was thinking about buying the Nighthawk 3.0 High speed cable modem router + voice.   My question is would it be a seamless transition...
  • vkdelta's avatar
    Aug 04, 2017
    you would need to call them to activate.
    you can try shorter hold number 1800-OK-BEGIN which is bit faster.
