fishinpole84
Oct 14, 2025Tutor
C3000-1000NAS
Have a N300 Wi-Fi Cable Modem Router that has been working fine for many years. Yesterday had power outage that lasted about 5 minutes. When power was restored, lost our Wi-Fi and NETGEAR Genie scree...
- Oct 14, 2025
Sounds like it might be a good idea to do a Factory Reset.
After a Factory Reset, the router typically appears at 192.168.1.1 and the web login credentials are "admin" and "password".
The WiFi credentials (SSID/password) are set to what is on the product label.
fishinpole84
Oct 20, 2025Tutor
Problem solved by advice from "CrimpOn"
