Yurii's avatar
Yurii
C3000-100NAS and readyshare doesn't allow to use password
Hi to everybody!
I have C3000-100NAS and couple days ago I bought external harddrive. I would to to use ReadyShare in my appartment and give access to some folder to my friends. For internal using in local network without password protection everything works fine. But as soon I add password protection to my share folders then I can't get acces to this folder. I have win10 home on my laptop and pc. Both said "Access is diened."
Does somebody has similar issue?
Thanks in advance!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Yurii
    Have you tried to use the same password that you use to log into the router settings?
    DarrenM
    • Yurii's avatar
      Yurii
      Hi Darren,
      Yes, I tried. I saw on the forum similar issues and I was trying all advices but no success.
      For any case current firmware version of router is 2.02.08
