imaflynn
Oct 22, 2017Follower
C3000 as base station
I have a new C3000-100NAS that doesn't quite have the range I want. Luckily, I have an old WNDR3300 and am trying to use this as a repeater.
I've made sure these four things match on both devices: SSID, mode, channel, and security. I can enable the "Wireless Repeater" function on the WNDR3300, but cannot find a setting for the C3000 to be the master/base station.
This may be more straightforward than I am making it. Any suggestions for making these two devices talk to each other as base station (C3000) and repeater (WNDR3300)?
1 Reply
> This may be more straightforward than I am making it. [...]
If you can run an Ethernet cable (or equivalent) between these two
devices, then configuring the WNDR3300 as a wireless access point
(rather than as a repeater) might make sense. (Probably better on a
different radio channel, however, in any case.)
"Or equivalent" would include a pair of Powerline gizmos.
