Ace06
Feb 27, 2016Follower
C3000 Printer to USB
Hello, and thanks for any help in advance. I have a C300 (N300) Wifi Cable Modem Router. It has a USB port. I also have a Brother (HL-L2300d) printer, that is NOT wireless itself, and instead nee...
Easy-Rider
Jul 20, 2016Aspirant
I have the same problem, with my new model C3700 (N600) CABLE MODEM/ROUTER.
I downloaded and installed the READYSHARE Control Center, but it does not see my USB printer.
I spent days getting the runaround, from Tech Support, and they wound up telling me, that my modem does not support a Readyshare printer. I think they were just trying to get rid of me because they couldn't solve the problem!
Does ANYBODY have a working printer, on my model mdem/router?
DarrenM
Jul 21, 2016Sr. NETGEAR Moderator
Hello Easy Rider
According to the product sheet and the manual this device only has the basic readyshare feature of hooking up a usb drive to the modem to share files does not have the Readyshare printer functions.
DarrenM
- Easy-RiderJul 21, 2016Aspirant
That's funny, because, on Pg. 33 of the User Manual, it says:
"The USB port on the modem router can be used only to connect USB storage devices like flash drives or hard drives, or a printer."
Somebody should update the manual!
