Ace06
Feb 27, 2016Follower
C3000 Printer to USB
Hello, and thanks for any help in advance. I have a C300 (N300) Wifi Cable Modem Router. It has a USB port. I also have a Brother (HL-L2300d) printer, that is NOT wireless itself, and instead nee...
DarrenM
Jul 21, 2016Sr. NETGEAR Moderator
Hello Easy Rider
According to the product sheet and the manual this device only has the basic readyshare feature of hooking up a usb drive to the modem to share files does not have the Readyshare printer functions.
DarrenM
Easy-Rider
Jul 21, 2016Aspirant
That's funny, because, on Pg. 33 of the User Manual, it says:
"The USB port on the modem router can be used only to connect USB storage devices like flash drives or hard drives, or a printer."
Somebody should update the manual!
