jamesli
Jul 24, 2016Aspirant
C3000 Wifi Drop-off Issue
TL;DR: The wifi drops off completely and doesn't link back to the Internet at least once a day, no power issues, no connectivity issues. I have the C3000 DOCSIS 3.0 cable gateway on Comcast Xfini...
DarrenM
Jul 26, 2016Sr. NETGEAR Moderator
jamesli
You may want to contact our Netgear support for this if you think is a issue with your modem they will be able to troubleshoot with you and figure out if its a faulty unit or not and find a solution if you are still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
ericpeters0n
Oct 03, 2016Aspirant
Same problem.
The reply above is not a solution...
- dolittle63Dec 14, 2016Aspirant
I am having the same problem. I cant keep my iphones in the house or my nest thermostats to stay connected. the hard wired connection is perfect.
