HannahLesesne
Jul 20, 2016Follower
C3000 won't connect to internet
All, I have internet when using an ethernet cable directly from the wall to my laptop, however I've been unable to get WiFi with this router. I plug the ethernet and coaxial cables into the back...
DarrenM
Jul 22, 2016Sr. NETGEAR Moderator
Hello HannahLesesne
If you are getting your internet out of the wall with a Ethernet cord then the C3000 will not work for you this is a modem with wifi functions and can not act as a router when connected to another connection. You will want to just get a router our router products all start wit Rxxxx.
DarrenM
