Markkoz
Jul 10, 2016Aspirant
C3700 - 1st Ethernet Port Doesn't Function
It suddenly stopped working after I forcefully shut down my computer. The computer detects that a cable is connected, but I get the "No connection available" yellow triangle with an exclamation in Wi...
DarrenM
Jul 12, 2016Sr. NETGEAR Moderator
Hello Markkoz
You could try to factory reset the device to see if that resolves the issue but you will have yo set up your router again. and if it is just broke and still under warranty then you will have to contact Netgear support.
DarrenM
Markkoz
Jul 29, 2016Aspirant
Of course I had tried restarting the modem when I made the original post and it didn't help. However, I restarted the modem after a few weeks and it fixed itself. The port now works again!
