313n703's avatar
313n703
C3700 - Missing Advanced Setup Menu
I just purchased this Cable Modem Router and wanted to setup Port Forwarding, but I can't because the Advanced Setup menu is missing. Looking at the User Manual, it should show just below the Administration menu. Is there a trick to getting it to show up or is my firmware just missing it? The current firmware version is V1.01.05.
TIA
1 Reply
  • I found the culprit. I have Adblock Plus Chrome extension installed and it was blocking that menu and maybe others.
