freddurst321
Nov 27, 2015Aspirant
c3700 as a repeater
Is there a link or instructions showing step by step how to configure the subject device as a repeater. thanks
TheEther
Nov 27, 2015Guru
Judging from the manual, the C3700 does not support wireless repeater mode. After all, it's a cable modem router, so it would not make sense for it to function as a repeater. On the other hand, if you are thinking of enabling bridge mode, which disables the router functionality, then that's done in ADVANCED > Administration > Router Mode.
freddurst321
Thank you for the reply. Let me ask my question differently.
i have a working wireless router. I would like to use the c3700 to wirelessly cover dead spots in my wifi. Does the c3700 do that and if the answer is yes how?
thanks
- TheEtherNov 27, 2015Guru
The C3700 cannot wirelessly cover dead spots in your Wi-Fi. But you may be able to use it as a wired Access Point. To do this, connect an Ethernet cable from one of C3700's LAN ports to your working wireless router. If using Ethernet is not practical, you can use Powerline adapters.
You will need to disable the DHCP server on the C3700. Then, set up the Wi-Fi network on the C3700. You can use the same or different SSID. In either case, just be sure to use a different Wi-Fi channel.
