Seanmccat's avatar
Seanmccat
c3700-can't conect
I bouth a c3700 back in December.  It was working fine for the most part until last Monday.  At that point, while it says I have a connection, I can not connect to any pages.   It does not matter if I try to connect wireless or by ethernet cable.  Moreover, I have tried to reboot and set to factor defaults, but it did not work it.   I called Time Warner and they sent out a tech.  He told me that the internet was fine, but the modem was not passing it through.   Does anyone have any suggestions?
  • Actually, I can connect to the internet on the guest network, but not through the ethernet cable or the other networks.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello Seanmccat
      If you tried factory resets and still cant connect it may be a hardware malfunction I would suggest contacting netgear support to check. If its still under warranty possible to get a RMA if its not working properly.
      DarrenM
