ng678's avatar
ng678
Guide
Aug 14, 2015
c3700 connection issue - only able to access a few websites
I came back from vacation to find that my c3700 would only access certain websites (Facebook, Gmail, Comcast, Wikipedia, and so on) but not the rest of the internet (Amazon, Reddit, CNN, Evernote).
After troubleshooting with Comcast (including trying Google's DNS, and resetting the router/modem to factory settings) I borrowed a Comcast device and was able to access everything fine that way (suggesting no issue with my cables or wiring).
My firmware version is V1.01.11, and I've posted a sample from the event log and my up/down info below.
Any ideas as to what could cause this issue?
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel693000000 HzLocked
Connectivity StateOKOperational
Boot State
Configuration File
SecurityEnabledBPI+
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1 QAM256 693000000 Hz7.9 dBmV38.6 dB00
2 QAM256 651000000 Hz8.8 dBmV38.6 dB00
3 QAM256 657000000 Hz8.6 dBmV38.8 dB00
4 QAM256 663000000 Hz8.2 dBmV38.5 dB00
5 QAM256 669000000 Hz8.4 dBmV39 dB40
6 QAM256 675000000 Hz8.4 dBmV39.2 dB00
7 QAM256 681000000 Hz8 dBmV38.6 dB50
8 QAM256 687000000 Hz7.9 dBmV38.6 dB00
Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate FrequencyPower 1 ATDMA 5120 Ksym/sec36500000 Hz39 dBmV
2 ATDMA 5120 Ksym/sec30100000 Hz39 dBmV
3 ATDMA 5120 Ksym/sec23700000 Hz39 dBmV
4 Unknown 0 Ksym/sec0 Hz0.0 dBmV
Event Log
2015-8-14, 16:58:25.0Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=6c:b0:ce:2d:d2:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:33.0Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=6c:b0:ce:2d:d2:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
  • I spoke to support over the phone and they seemed to think that this was an issue with the router/modem settings, but the person I spoke seemed to be reading off a script and wasn't able to tell me what firmware I should be running.
    It also doesn't make sense since I hadn't changed any setting when the issue first popped up.
    Does anyone have any ideas please? Support has been very frustrating.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello ng678
      Have a couple questions for you
      • Is issue happening on both wired or wireless?
      • Is issue happening on all devices or just one?
      • Try a different browser and reset the Internet history and cache.
      • Make sure Advanced>Security> Block sites is configured to Never.
      • Were you using parental control feature previously.
      DarrenM
      • ng678's avatar
        ng678
        Guide
        This issue occurs for both wired and wireless, on multiple devices (including a desktop windows 7, an iphone, and a macbook), also with multiple browsers on these devices.
        No sites are currently blocked, and I have not ever used parental controls (although I cannot tinker with parental controls as doing so requires accessing the internet).
    • Reckoner's avatar
      Reckoner
      I share your pain. I'm having similar problems and the Netgear logs indicate the trouble began recently.
      Netgear customer support has been almost useless.
      • ng678's avatar
        ng678
        Guide
        I've done some googling and seen people having similar issues with a variety of netgear devices in the last three months (perhaps a firmware issue?) but none of them posted a resolution other then trying another vendor (and I've had similar struggles with customer support).
        I'm happy to help with what I've learned so far though!
        Did you try another device? I borrowed a friends and it did get a connection, so that's why I'm pretty sure the issue is with my netgear device.
