krward's avatar
krward
Follower
Oct 08, 2014
c3700 connection issue
Well I tried Netgear Support and they were zero help....
I have the C3700 - 100NAS
Everything worked fine for a couple of months but now nothing except my 2 computers connect and works like normal with the router.
My cellphone, printer and TV all say they are connected to the router and when I log on to the Genie it also says they are all connected.
However the internet/apps load incredibly slow or don't load on my cellphone. The printer keeps saying it loses connection to the computer and the TV won't load Netflix or anything else. If i reset the router everything will work fine...for about 2 minutes.
I've tried resetting and there is no signal interference. I cant seem to figure out why my computers work fine but nothing else does...any ideas?
  • I'm having horrible problems too with the c3700. It is a huge racket to extort money from their customers. I have no way to update the firmware, doesn't give that option in the router settings like the help page says. Customer support says it's not a hardware issue, and they an fix it but since I just passed my 90 days I have to pay them. They won't replace the modem until I pay them to TRY to fix it over the phone first. My isp (which is wow) came out and looked at everything and it's clearly a a modem issue. I can't connect on wifi or wired. I went to a coffee shop and downloaded the supposed "fix" and all it does is reboot the router. Phone support told me there was a free chat (lie) or I could find the walk through (which des nothing to help my problem). Only two options are to give them money for a product I ALREADY PAID FOR!!!!!
  • I'm having same issue, really frustrating. Customer support wants to charge you more than the router costs and says they can fix it! No thanks, I'll buy a new one and it wont be NETGEAR!!!! Worst customer service and clearly this is an issue since so many of us have the same problem.
    • Jdcrow's avatar
      Jdcrow
      I had similar issues, my 2.4g internet and direct lines work, but it seems to only be a 5g issue.
      I looked everywhere and couldn't find a fix, so I decided to try it myself.
      I cleared all event and access logs on the device, then I use a WiFi analyser to find a better channel and changed the channel to a more clear one.
      I then rebooted and now on my tablet and cell phone the 5g works great again. On my wife's inam still having minor issues. Hope this helps some of you.
  • Tech Support is USELESS! They ran me around, in circles, for 4 days, with no solution.
    Does ANYBODY know how to set up a USB printer, with ReadyShare?
