thekid1751
Aug 12, 2016Aspirant
C3700 Drops Connection to Devices
I'm having an issue with my NetGear C3700. I've been using it for about 6 months with no issues. This past month, I've noticed it randomly drops connections to all wifi decises it's connected to....
thekid1751
Aug 20, 2016Aspirant
I tried all of those and still have the issue with all devices.
- mybudfrogsNov 25, 2016Aspirant
I have been having the same issue. I just did all the settings in the link above but I have little faith in that. I bought a n600 router for the speed but it seems to me that reducing the speed to just get the wifi to work is BS considering I bought it for the speed in the first place. Either give us a firmware up date that fixes the issues.
I am the only user on the system. One cell phone connected along with a laptop. My xbox is hardwire connected to the router.
What is strange is if the 5ghz stops working I can switch to the 2.4ghz. Then when it stops I can then switch to the other. It is getting hung up on something. I don't know what but I live in an isolated area so I have no channel interference to worry about.
- one2admyrMar 06, 2017Aspirant
My continues to do the same. Customer support won't help unless you pay for it which costs more than the router itself. I will see if anyone can help me or if I can figure out a solution soon. Or next week I will go buy a new router, for sure not a netgear!!!
